Hi, does anyone know if the tv above supports 2160p hdr for ps5, when I try to set it to 2160p on the ps5 settings it is saying ‘the input device does not support this’. Also if it does how I could fix this.
Thanks.
Is the HDMI cable between the two 4k compatible
and have you set the Sony HDMI setting to Enhanced for 4k content.
On my Sony Bravia the path to the setting is as below, yours may be
slightly different.
Click the Home button on the remote control.
Then navigate through the on screen menus.
System Settings> Setup> Av Setup> HDMI Signal Format> Enhanced
slightly different.
Thanks Davey this worked!
Yes joe!
