After setting TV to accept wifi using home router and watching you tube - after switch off and next day attempted switch on - cyan (blue) LED light came on (not flashing) . TV is dead and unresponsive. Repeated forced factory reset attempts without success. Sony troubleshooting indicates that Cyan light should represent screen mirroring ? TV still dead - with no other solution in Sony troubleshooting - help
@stuarts It might be on the demo mode or something, have you tried forced factory reset? take a look here: https://www.sony.co.uk/electronics/support/articles/00274122?link-header
@stuarts If there are any connected devices to the TV disconnect all of them. If the issue remains, you can use this link to locate the nearest service centre to you and arrange inspection for the TV: https://locator.sony/en_GB/servicecenters/?zoom=5&latitude=54.29088&longitude=-2.37305
