i am setting up a network on this tv. In the "activate enhanced features" menu it says there is a "send from pc to "function which i can turn on but i have to install a plug in on my pc. I have looked on the sony website but cant find a correct download.. can anyone tell me where to find it please?. Also once installed what does the pc to tv function enable me to do?.. is it just static pictures or live streaming movies etc from my pc that i can watch on my tv?.
Once you get the network working try installing this media server http://www.serviio.org/ in your PC; it seems to work very well with Sony TV’s. If all is done correctly you should be able to see pictures, videos y music from your PC in your TV.
