Can anyone help my tv for the past few days has had the channel number and when sky is on it comes up with the channel number and 1080i/50 i have gone through the settings loads of time.
Does anyone have any sudjestions. sorry for any spelling as i have brain injuries as a british soldier
thanks everyone
Hi there
Try pressing the i+ button on the remote control. You may need to press it a couple of times as it cycles through other options. I have circled the button in red on the picture below.
Thats great thank you for future ref if i cant find the remote to sort it is there away to do it on the main tv
I dont think so to be honest. However, if you cant find your remote - you cant accidently press the i+ button to enable it, so... (I dont believe it comes on automatically anyhow)
Im glad its worked anyhow.
once again thank you
