How is possible transfer photos and videos between Nokia Lumia 920 and Sony KDL-46W905A TV? Connection with NFC and directly with USB cable dosent work.
Ennberg
Download Nokia "Play To" from windows app store, it's the DLNA compatible application for windows mobile. In order to share music/video/photo you have to connect both devices on the same home network or via wifi direct.
