Would the Sony 2.1 Channel HT-CT260 Surround Sound Bar for TV with Wireless Subwoofer be compatible with my Bravia KDL-55HX823.
yes i believe so, you will need to connect the optical digital cord (supplied) from the tv to the soundbar then on your remote press Options, scroll to speakers and set to audio system and thats it.
