I have a Sony Bravia KDLV4200, manufactured in 03/09. I cannot find it in the list of Sony Bravia TV products. Is this model compatible for Irish Saorview digital switchover?
Hi marjoriepower.
You need to add the screen size to get to a valid model - for example KDL-32V4200.
Your TV has a digital tuner DVB-T/DVB-C and is compatible with the Saorview DTT transmitters and OK for digital switchover.
Have a look in the User Manual on Page 6 on how to tune in to digital broadcasts: -
http://pdf.crse.com/manuals/4114592111.pdf
Hi marjoriepower.
Thank you so much for this information. I will now check out the User Manual as suggested.
Wish me luck as I'm not very technically minded!!!!!!
MARJORIE
