x
Replacing hard wired ac power cord in TV KDL40EX503
SOLVED
profile.country.GB.title
busb0y
New
Hi, I want to replace my short hard wired ac power cord in KDL40EX503. with a longer cord. Its not simply a plug in job, its hard wired which makes it a pain. It looks like the back unscrews to enable change.  Anyone previously done this? Is it easy or does it need a professional?  Thanks
1 ACCEPTED SOLUTION
Accepted Solutions
busb0y
New
Hi Nic, Thanks for your reply. Yes the easy way is to use an extension which is fine electrically but I want to hide the lead in an existing plastic conduit. The wall mounted TV its replacing had a plug in power cord which I replaced with a longer one (easy!) and was able to hide it neatly. The size of the plug and extension socket is far greater than the conduit, hence my problem. Maybe I will need to replace the conduit with a bigger size but this would not be as neat. If the TV was table mounted an extension lead would be no problem.
3 REPLIES 3
profile.country.DE.title
IamNic
Expert
Hello @busb0y,
I personally wouldn't mess with a power cable if it is hard-wired to the device.
What speaks against using an extension cord?
- Nic
busb0y
New
mikeharbour
Explorer
Its not really hard wired in. One screw opens the cover then there is a little white clip inside. Squeeze the top of it anmd it pops out. Now does anyon know where to get a longer cable with a white clip on the end?
