I have a STR-DH820 AV Receiver and the remote is getting a little unresponsive (yes changed batteries). I can't find a replacement on Sony Online shop, am I missing the replacement remote on the shop or is an exact replacement not available?
Hi olpartr,
welcome to the Sony User Community Forum..:smileyhappy:
Sony do not usually sell replacement remote untis via there online store but you can usually find these parts at 4ourhouse..:smileywink:
Here is a link to the remote on the 4ourhouse site..
I thought I had an issue with a remote but when I got the new one I still had the problem. Might be worth trying to borrow a remote to check it actually is the remote at fault.
Hi olpartr,
