Hi!
Have SONY BRAVIA KDL-40X2000 with remote control RM-ED006.
And now this remote control is dead.
I can't found RM-ED006 in shop (and internet-shop) in my country.
Do khown someone the other model remote control for SONY BRAVIA KDL-40X2000 ?
Hi there
Ive checked all the usual places for Sony remotes and all have come back with 'out of stock' item is discontinued. If you want the exact same one - maybe ebay might have it.
However there are others that will work, just search on google. I have found this (UK)
http://www.remote-controls-shop.co.uk/catalogue/Sony/RMED006
Thanks a lot, Quinnicus
