Hello, I have a KDL-37EX403 bravia tv. There is no registration code when I go into Activate Enhanced Features (using the Home button on the remote). I need this to create Sony Essentials account. The device is registered. Where it says Registration Code, it says the device is registered but there is no code!
Please can someone help?
Message was edited by: Rosekia
I have a Bravia kdl-60W630B and i can get the registration code in order to set my essencials account.
@Rosekiawrote:Hello, I have a KDL-37EX403 bravia tv. There is no registration code when I go into Activate Enhanced Features (using the Home button on the remote). I need this to create Sony Essentials account. The device is registered. Where it says Registration Code, it says the device is registered but there is no code!
Hi
I have a sony bravia tv model type KD-49X8309C i need the code to watch prime TV
From stuart King
Hi I have KDL-40EX720, i also see the same message device registered but i couldn't find the code. can any help
From the link attached by Roseika above (this one) it seems that this feature is only available for Blu-ray players and Amps, or at least that's all the options I found for codes in the Registration section.
Hope this helps.
- J.D.
BIVbsjh
