- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
i was recently watching netflix on my sony KDL-42W653A tv and the tv went off and a red light came on at the bottom of the sense bar but then the tv came stright back on again.
is this anything to worry about ??
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
Sounds like the TV crashing. Nothing to worry about. Every now and then, like a PC, it will crash. However they should be few and far between. So if it happens often (or at a particular point), then theres something wrong. If the TV doesnt turn on, and the red light blinks (in a set pattern), then this normally is a hardware fault.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
hello thanks the tv has not done is since and is in great working order
