Is it possible to stream Really TV to my smart TV - KDL42W705B
If so how?
Thanks
Ahhhh gotcha now.
Simple answer is no. But there is a however.
You could connect a HDMI cable from your PC/Laptop to the TV and display it that way - its the simplest but messiest solution - but works. I do it all the time (not for Really TV though).
However if you have Win8.1 and an Intel network card, I belive you can display the screen from the PC/laptop wirelessly using Miracast. However im not sure how to do it (as ive never done it). There is a thread on this forum somewhere with some links that may be helpful. See HERE for more info.
Hi there
Are you talking about channel number 17 on Freeview??
Other than that, if its a Sky channel, you need a Sky package.
I have Freesat...not sure if it's on that. But it's also on the web...jsut wondering if there's a way to stream it from there.
http://really.uktv.co.uk/on-demand/
Ahhhh gotcha now.
