A display keeps coming up on my Bravia screen giving my model type followed by a series of what is available on my tv eg. pc input,usb play,bass booster,usb play,freeview.
Could my set be in Shop mode do you think?
Message was edited by: wltrspatr
yes, I think your TV set is in a Shop mode and to exit that you have to do a factory reset. then an initial setting wizard will start asking you to select shop or home mode. bare in mind that with factory reset you will lose the present settings.
many thanks
