Hi there
Unfortunately they are the only manuals available:
Is there anything in particular that you would like to know, as maybe one of the community may be able to assist? And if you have a bunch of questions, by all means fire away
Hi there
Trying find user Manual for Sony Bravia model KDL-W80xC
