I am elderly and this is my first 'smart' tv it is a.........
Bravia model KDL-48W D653 new this month.
It is excellent after my old Humax and it was set up for me as I wanted it and I have managed to go thru the manual to do other minor adjustments such as sound/picture.
What annoys me is that every time I change progs, mute it or do anything else on the remote - a 'bar' appears at the top of the screen for about 5 or more seconds giving info like time, stereo number?, HD......?
I never had this on my old TV but I suspect it is because it is 'smart'. The TV is the best I have had but how can I get rid of this bar completely.Tried pressing the 'i' on the remote but it just comes back!
Said something in manual about home - settings.........but I tried this and nothing happened - there was no 'off' switch.
Thanks everyone
moggie
Hi @mogggie and welcome to the Community
Hang in there, I'm sure someone will be able to help a bit later.
(Unfortunately I have an old Bravia and can't replicate the trouble you're having,)
Enjoy the forum in the meantime
Hello there
Unfortuately you cannot perminently disable the information banner/bar at the top of the screen. The only models that I am aware that you can do so, is the Android based models.
