- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Sony W829 - Media Player - 24p playback via DLNA/USB?
Hi all,
I own a Sony W829 TV, I can successfully play MKV files via DLNA/USB using the in-built Media Player on this TV, but there is no way to check if it is playing at 60p or 24p.
I have tried multiple files.
Any advice?
DiNZi
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
The specs state 24p True Cinema is supported. I believe you needs to set "Scene Select" to "Auto (24p Sync)"
http://helpguide.sony.net/gbmig/C5331001/v1/eng/c_aadjust_scene.html
Also have a look at "Picture Mode" for "Cinema 1" or "Cinema 2"
http://helpguide.sony.net/gbmig/C5331001/v1/eng/c_picscrn_picmode.html
One last thing, have a look at "MotionFlow" and "True Cinema"
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Any idea how to detect if the TV is then playing in 24p and not 60p? Is there some sort of button on the remote or can I detect this some other way please?
Btw, thanks for the quick responses.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Im not really sure to be honest. What does it say when you press the i+ info button when playing back a file? Thats really the only way.
Once again, the supported codecs list for your TV, only mention 30fps and 60fps.... as maximums
Its a little confusing too. 24p via HDMI is definately supported, but not much info on usb/dlna file playback.
