- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
May 2014
May 2014
It has worked fine for about 6 months, but now it consistently crashes after about half hour on each movie.
The error message I get is couldnt connect to server.
Then I have to restart my laptop for the Homestream icon to reappear on the Tele.
Even then sometimes I cannot connect.
Any idea what is happening?
Many thanks.
Russ
1 ACCEPTED SOLUTION
Accepted Solutions
Anonymous
Not applicable
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
May 2014
May 2014
Hi there
Without being specific (as I dont know the model of your TV) - there are a couple of things I would recommend you to.
- Remove all traces of Homestream off your laptop (and reboot laptop)
- Goto the TVs Settings > Network > Home Network Setup > Server Display Settngs - DELETE all traces of Serviio off your TV, by pressing the [Options] button on your remote control
- Go back to the TVs network Settings and choose "Network Setup" - Resetup the TVs Network settings and give the TV a FIXED IP ADDRESS, by choosing "Custom"
- Give your Laptop a FIXED IP ADRESS too - might assist.
- Re-install Homestream on your Laptop and config as per normal.
Give that a go anyhow.
Cheers.
1 REPLY 1
Anonymous
Not applicable
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
May 2014
May 2014
Hi there
Cheers.
