It has worked fine for about 6 months, but now it consistently crashes after about half hour on each movie.
The error message I get is couldnt connect to server.
Then I have to restart my laptop for the Homestream icon to reappear on the Tele.
Even then sometimes I cannot connect.
Any idea what is happening?
Many thanks.
Russ
Hi there
Without being specific (as I dont know the model of your TV) - there are a couple of things I would recommend you to.
Give that a go anyhow.
Cheers.
Hi there
Cheers.
