Hello all,
I have a Sony Bravia model KDL 32S3000. I have lost the remote. I need a replacement. Can i buy any Sony remote or is there a specific remote i need to buy. Any suggestions on which remote i need and potential online stores selling such remotes would be much appreciated.
Thanks in advance,
Rhys
Hi Rhys,
You should be to order a replacement remote from Sony's dedicated spare parts provider Nedis, the part number for your Bravia is 148015811..
Alternatively a have a look for a universal remote may be a cheaper option..:smileyhappy:
there you go, treat yourself !!
http://www.amazon.co.uk/Sony-KDL-32S3000-Original-Replacement-KDL32S3000/dp/B0037IX0JA
Hi Rhys,
i have lost my remote when i was moving could you tell me how much it would cost me
Hi there
What model tv do you have?
I would like to buy new remote
