I have a monster surge protect with a KDL52EX700 & an xbox 360, amp plugged into it. I added the amp & 360 to the surge today, but I am unsure if this is related but now my 52EX700 will completely go black w/no sound. The green LED status light remains on during this outage, I have never upgraded the firmware but don't see how this could be the issue as I have had uninterrupted performance since purchase several years back.
Thank you for reading this & if you have any advice please let me know!
Hi there
Not knowing your particular setup fully - you might be overloading the power circuit. Try unplugging everything - then just plug the TV in and see if that works. If that works, slowly add another piece of equipment and test each time.
Upgrading the firmware is generally a good idea as well
Hope that helps.
Thanks for the reply! We've unplugged amp/xbox, leaving the original plugs in. My girlfriend was home all day & the updated report is that the issue continued to the degree that it started to flicker twice in a minute, still random intervals, eventually a "no signal" appeared as if the HDMI was unplugged.. I fear for the worst. Should I at least try replacing HDMI cables? How likely could it be cable box?
Cheers!
Hi there
Ahhh, I think I understand now, from your original post, and with your followup.
The "No Signal" message is to do with your aerial cable/reception. Have a look at your cable to see if its in good working order (ie not falling to bits). Also have a look at the signal strength and signal quality when this happens. Try replacing this cable with a better one (with shielding preferably)
Also, go to the following website, enter your post code, and if your local transmitter has any problems, hopefully it will be displayed.
http://www.ukfree.tv/starthere.php
If you have an aerial on the roof - ensure that it is not clogged up with leaves or any debris (especially this time of year).
It could also be due to 4G interference - See website below, as you might be entitled to a free filter.
Hope that helps.
