my bravia wont connect to the internet? im using a cable from router to tv.
Hello Evan,
It may be worth contacting the supplier (Belkin) customer support as they may have already heard of some issue and have a fix they can help you with.
Sorry I dont know the number or cost of call, but it may be cheaper than buying a new router.
If you do contact and there is a solution, it would be good to include here for other customers who may have an issue.
My Sonia Bravia KDLS203000 will not connect to the internet. This has happened before when there have been updates. I have tried disconnecting and switching on and off etc, but to no avail. Does it need updating with a usb and if so how do I do this?
JMatthews
