x
profile.country.el_GR.title
paterakisz
Visitor
KLV-L32M1
Hello. I have the tv wega KLV-L32M1. Can i connect it with my laptop, so i can see youtube etc? It has only 3 scarts. Anyone can help?
1 ACCEPTED SOLUTION
Accepted Solutions
profile.country.en_GB.title
etritd
New
depending on the video-out of your laptop you might need an adapter. maybe something like this one on the picture:
and then you need audio-out adapter:
and you plug them into RCA video-in of your TV with corresponding colours.
if you really need to use the the scart input, you might need to use this adapter:
1 REPLY 1
etritd
New
