hi i cannot find a replacement table top stand for my KDL-40U2000. I had it wall mounted but now want to put it on a unit i have. I dont want to buy a big bulky furniture type stand. I just want to replace the table top stand that i have lost. any ideas? i have spent hours looking for one but they dont seem to exist. thanks. craig
A replacement stand should be avialble online from 4ourhouse or tel 0844 324 7129..
Alternatively any other VESA compatible stand should work..
