My kdl40ex503 turns itself off then back on. The picture goes blank, 5 seconds later the sound goes off and a red light comes on, 1 second later the set comes back on, the sound comes on and the picture re-boots through the 'sony' screen as normal. This happens every 5 minutes (almost exactly). We've tried resetting the sleep timer and done a factory reset. When the set was off for a few days (unplugged as we were on holiday) it was fine when we turned it on again, lasted 3 hours no problem. The next time it was turned on the fault was back.
Any sage advice?
Thanks for the reply, I've already e.mailed this to them and waiting reply. It will not accept a firmware update either which I have asked them about. I like to get feedback before I venture into unlimited cost repair land!
