Hey! Have owned a Sony KDL-55w905a in nearly two years and it is absolutely great except for one thing, as soon as I use the youtube app freezes the image and the TV restarts. This has been done from the very beginning between 0-5 minutes while using the app. TV has the latest software and I drive over wifi. Usually use the youtube app in my harman kardon system instead, and then it will go well, also over wifit. What's wrong?
Sincerely, / Kjell
Hi there
Can you please try a factory reset of the tv, as this should clear any 'gremlins'
Please post back once you have done so and tested youtube again.
Hello and thanks for the reply ! Have done this before without any result but tested once for safety's sake and now it works without any freezes !!! Thank you very much! Sincerely, / kjel
