Hi, I have the KDL-55W905A and I was wondering, what is the most suitable way of converting my vga connection on my computer to connect it to the television? I also require sound too, so i'm not sure if i require another cable for that? Thanks again guys
Hi there
As the TV does not have a VGA connection, what you will need are additional leads, or a VGA to HDMI converter.
Amazon has loads of these, such as:
http://www.amazon.co.uk/Neet%C2%AE-Converter-Supports-Computer-Lifetime/dp/B002C6NP5C/
Just read the reviews and ensure that it does match your requirements.
