I have couple question, which I wasn't able to find in forums.
First - how do I connect to screen mirroring, I do everything by the instructions, I see connecting in tv and laptop, and then it says failed to connect, I don't understand what I am doing wrong.
Second - I do now understand how to add new account , I don't even see this option in my tv, as far as ive seen in forums , it said go to settings and add account,well I do not have this option anywhere .
Third - How do I get to browser, like facebook, google & other websites ? I don't have any 'Enter URL' options anywhere.
these issues i have which i dont understand ...
You don't want a PS4 Pro (4K), you don't needed because your TV is 2K (Full HD)...
This choice only for 4K feature, not for most powerful feature who PS4 Pro offers...
Manolo
First - If your PCs is 100% Miracast compatible maybe the problems are the wireless card drivers...
Second - Have you read on Account for Android TVs? Because your TV isn't an Android TV.
Third - This series haven't a web browser and so you can't surf on web.
Manolo
hi,
how do i know if my pc is miracast compactible ? and I dont really know what is wireless card drivers. I could connect screen mirroning through my phone tho.
So it means I am not able to make any account ? I still have 1 email, ive seen somewhere in settings, no i cannot find,e.g. i go to media and i see Bravia media and then my email media too, but its empty
Ok,
press Win key + R key > write dxdiag.exe > Yes to the Internet connection request > Click on Save all informations...
In the saved file search the Miracast string... There's your answer...
"I still have 1 email, ive seen somewhere in settings, no i cannot find,e.g. i go to media and i see Bravia media and then my email media too, but its empty"
My fault but I don't have understood...
Manolo
Miracast: Available, with HDCP
Your PC is Miracast compatible, now you can find an update driver for your wireless card, go to "Devices manager" (right click on Start) > Drivers module > Search an update driver...
A new driver I think is the only way...
Manolo
i press on 'scan for hardware changes' nothing happens 😮
you see, when i try to connect to screen mirroring, after few seconds on connecting it says disconnect first, and then the search will begin,on my laptop
Have you tried to delete the PC if it is now is already registered from TV? In Mirroring list...
Manolo
i treid to delete my laptop before in wifi direct settings list , same list is in mirrorring list
In this case I think it is a driver issue, even I when I try to connect an area of 3 Pro for Android TV connection does not establish... At this time, maybe in a future with a new driver...
Video drivers also are upgraded?
Manolo
