x
KDL-47W807, HD playback problems, menus and graphics disappear
SOLVED
KDL-47W807
Member
I have the KDL-47W807 and when I play 3D movies from an external hard drive plugged into the USB input on the side of the TV and during the course of the movie playing change to a television channel (e.g. by pressing 1 or 2 on the remote), all the graphical menus disappear from the TV, and it is thus impossible to navigate the TV when you cannot see what you choose with the remote control. There is still image/picture on the screen from the television show, etc., just not the menus, graphics etc. It is only by shutting down the TV completely that the menus return again. I have firmware PKG3.901EUA. What's wrong?
2 ACCEPTED SOLUTIONS
Accepted Solutions
KDL-47W807
Member
Thanks, I have already reported everything to Sony and they are looking in to it. Yesterday I upgraded the firmware to PKG4.000EUA. I will test later on if this could resolve anything.
KDL-47W807
Member
The upgrade to PKG4.000EUA has solved the problem!!! Menus are back, and you can change directly from a 3D-film to a tv channel with everything working flawlessly! GREAT!!!
10 REPLIES 10
KDL-47W807
Member
Today I visited the shop where I bought the set with my hd with 3D-films and tried  the same scenario there. The problem did not occur with the dealer's show model KDL-47W807, but the firmware on his tv was an older version than mine. I suspect the new firmware (PKG3.901EUA) to be the cause of the problem, but since you cannot load an older firmware in the set, I can't test it on my own set. I have also tried a factory reset without luck...
KDL-47W807
Member
The TV-set from the store I bought it from has this firmware: PKG3.710EUA and it does not have the problem with the graphical menus disappearing when switching directly from a 3D film to a tv channel without turning off the 3D setting.
Anonymous
Not applicable
Hi there
Reading though your problem, I think your best bet is to contact Sony Support directly.
See : http://www.sony.co.uk/support/en/contacts/tvhc
KDL-47W807
Member
costasziros
Member
when your TV play a video form usb or a blueray from playstation - blueray the remotes controls both of them recognised the playstasion and they are controls for playstation at this momment.
If you want you can click at sync menu and you choise
1)if you want one control to be for TV menus and the other for playstation menu.
2)both controls to be for TV menus
if you have the second control (smart control) you click at ke pad button and then you click that image to select device.  TV - or Video to pair with any control you want
So all menus fron TV is available to you
costasziros
Member
this image you must find when you push on smart control the button "key pad"undefined
costasziros
Member
Sorry mistake you dont push that button on picture...you push the buton "sync menu" and the you can choose the tv menu
KDL-47W807
Member
Dear Costasziros: Thanks, for your answer, but I guess, it was a solution for my problem, anyhow. But thanks for your time. Cheers.
KDL-47W807
Member
