Hi.
You have to try with the “Subtitle Settings” button (upper-left the second one) http://pdf.crse.com/manuals/13MW802111/EN/c_dispsnd_europe_ga_sub.html
But I think the solution is in Option Menu (OPTION button). When in USB playback, set Subtitle “OFF”.
| Non mi aspetto nulla. Non temo nulla. Sono libero. - I hope for nothing. I fear nothing. I am free. (N.K.) |
I have just bought a KDL-32W654A and put a Western Digital Elements 500Gb HDD in the USB port. It passed all the recording tests, but the TV exhibiting exactly the same 'Subtitle: Off' behaviour you mention. Really annoying.
I can see this telly going back 😞
Same here
KDL-55w805
PKG3.710EUA
Western Digital MyPassport 1TB
much worse on a programme from Channel4HD (Double your house for half the money)
- it appears every minute or so randomly even during the adverts
not nearly as bad on a programme from STVHD (Vera)
quite painful
Hi there tinewnh64 and mikie1,
There have been some issues with some TVs. Please could you take a look at this TV update from Emily_F yesterday, to see if you think you have a similar issue?
Many thanks,
Pascale_F
Thanks for this. I will give it a try over the next couple of days and see if the 'subtitle: off' problem has resloved on my w654.
