There is a new firmware update link posted on the support site, however there is no detail as normal and the link doesn't seem to work. Would anyone happen to know what the problem might be, it appears to be the same on all European support sites.
Hi
Have escalated to engineering to get them to investigate. If your TV is left connected to the Internet, it will download it automatically anyhow.
Thanks for flagging...
I wasn't aware that firmware updates are possible automatically online direct to the tv, I have always used a USB memory stick before downloading the files from your support site. But thanks for letting me know, do I need to leave the tv in standby connected to the Internet for the update to work? Or will it update when the tv is active?
