Hi there
If the router is only a few feet away in the same room - it might be best to use an ethernet cable instead anyhow. Gives a much more consistent performance. There's almost an infinite reason why wifi drop-out and can be hard to diagnose the cause.
Hi there
When it does this (drops/works slowly), how many bars does it display for reception? If its only 1 or 2 bars, then the signal is rather weak for it to work properly.
worth noting as above, is the router in the same room?, if its in another that wont help matters, as far as Sony tv's go its not as strong as the other equipment for recieving signal
