- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hello. I have a problem with my KDL-40R450B. The response from the remote control is shocking. Very slow reaction and from time to time just jammed. I'm not talking just for changing the channels, but also when I use the menu, or use the flash drive.
Is there any way to fix this, because sometimes is really annoying.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
Can you ensure that you sre on the latest firmware for your tv. If so, can you do a factory reset, as this can cure many issues.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
The firmware is the same from the day I bought it, a year ago. From youtube I saw how I can upgrade it by flash drive. Basically I don't mess with something which I don't know. So I'll be very grateful if you can tell me from where I can download it.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Find it and done it. Works perfect! Cheers mate!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Excellent. Glad its worked
