Hi support,
i've bought this TV and can't find any firmware and ability to install/use skype. This is the TOPmost series u had and i can't believe that there is no solution for this.
Please advise me what to do to solve this issue.
thx in advance.
BG, Yuriy
Nothing I can see says that this TV has the ability to use Skype. If it doesn't support it now, it cannot be updated to include it in the future. The TV has to be designed to cope with it from the beginning, so it won't be coming i'm afraid.
