Hello,
I have a funny problem.
I'm on the last step of Divx Registration.
But my 40EX520 is not playing the registration .divx video, says: "Playback not avaliable"
Therefore I can't play any kind of video file.
Thank you for your help.
Just to be clear - Divx registration is not needed to necessarily playback Divx files - thats simply for premium divx files ( and frankly I'm not sure you can actually buy this from many places)
If a file isn't playing back for some reason, its likely that the codec/container isn't supported natively. So you can either re-encode to a compatible format or use a DLNA transcoder like Serviio to do the work for you via your PC.
Thanks
Hi iozturkan, and welcome to Sony Forums
I think you are trying to play Divx HD file which are not supported by Sony
See this link Which codecs are supported by the television set? for a similar model
http://support.sony-europe.com/tvhc/faq/faqkb.aspx?site=odw_en_GB&d=kb&KBS=&m=KDL-32CX520&f=
Regards,
Message was edited by: KDL-CX520
thank you, i know that table, i have tried nearly all, but all i get is that error "Playback not avaliable".
Thanks
30:F9:E5:7D:03
