My TV occasionally stops seeing my cable box when it is connected to the CABLE input. I have to manually move the cable to HDMI1, and select that input.
After a weeks, it will stop working on HDMI1 and I have to go back to the CABLE input! Anyone else have this problem? Is there any solution?
Hi there,
Can you let me know if this has only be happening recently, as it could be the cable that's causing the issue.
Best wishes,
Sean
Hi and thanks ,answerd so quickly, pratar du svenska? if not no its not the cable ive tryed 4 diffrerent cables in verouse leangth´s
Hi again,
I would recommend getting in touch with the support team here who will be able to look into this.
Best wishes,
Sean
