After some use, my Sony Bravia tv ( KDL-32WD757 ) is now saying when I want to start Netflix that the tv ins't conected to a wifi source. I tryed to reconect the tv many times, but it doesn't see any wifi bnds at all. I also restarted the tv and router with no succes.
Just make sure that your TV is up to date, you can get more info how to update it from here: https://bit.ly/3A5OCsI.
The, try to connect you TV to the internet by selecting the WPS feature, it will be much easier. Press Home-Settings-System Settings-Setup-Network-Network Setup-Easy-Then select WPS.
Hope that works
-Piscie
