I've asked this before and have waitied for firmware updates. The last update made no difference. Factory reset has had zero effect.
I understand that 'Sony Entertainment Network' is only available on post 2010 models. This is a 2016 Television. I'm trying to get the TV registered on SEN so I can view the same content that I do on another set which is a 2013 KDL-32W653A.
Image attached shows the only available apps. Sony Entertainment Network is non-existent. Can anyone help??
Hi there
I remember your other thread:
https://community.sony.co.uk/t5/televisions/kdl-32wd603-limited-apps-and-no-sen/m-p/2188265
The apps available on the 2016 WD6 series TV is different to the 2013 W653a TV. Other tjan the Amazon app - which i have no further news by the way, you are not missing any apps.
Also, you no longer need to register 2015 and 2016 non-android smart TVs to SEN to activate apps.
https://us.en.kb.sony.com/app/answers/detail/a_id/65092/
Hopefully this explains things better
Hi there
Hello
The Amazon app should now be available, one you have updated your TV. Please see the following link: http://www.sony.co.uk/support/en/content/cnt-dwnl/
