can the apps be update / deleted (there is a lot of junk? Where is All4 My5 or ITV?
Hi Peter,
I'll see if I can find this out for you.
Thanks,
Pascale
Hi Peter,
As far as I can tell the apps on your TV are services provided via the Sony servers.
You can only filter what you see on your Home screen (adding/removing from the all apps list). As for All4 and ITV, these are sadly not available for your TV. However, My5 should be available on your TV. If you can't find it, I'd recommend refreshing the internet content under Settings-Network to refresh your apps list.
All the best,
Tenneen9000
Hi
Thanks for your help, I have updated the internet content, there is no My5 that I can see, also I cannot see how to get rid of the not working Demand 5 from the "My Apps" selection. There is so much junk in all apps - Sony could do better in the digital age
Hi Pascale
Thanks for the response. I have update the internet content, but i am stuck with a not working Demand 5 in "My Apps" and no access to My5.
Hi you may have to reset your TV to factory settings and start over.
Hi Otters9
I may do this but it seems drastic and should not be necessary. However thanks for your help, appreciated.
