What sort of memory stick do you need?
USB 2.0, not 3.0?
Capacity: 32Gb? Would 64Gb be better? Or would 64Gb not work (I've seen a comment somewhere to this effect)
Speed: at least 20Mb/s?
Thanks.
Hi there
Below is a screenshot of the notes for your model TV. Even though 32GB is the minimum, i wouldnt bother. A 64GB USB3 drive on Amazon goes for less than £15.
