I have verified that
- the HDMI cable is high speed
- HDMI 1 (ARC supported) is being used on TV
- HDMI port is ARC supported on BR player
- ARC support settings are set to 'Auto' in the BR player
Nothing still. What am I missing?
Hi there
It appears you have the right compatible hardware, so lets concentrate on settings.
On the TV:
On the Bluray player:
As you have already got ARC set to Auto on the plqyer, there really is no other settings to change. So if it still fails:
Hopefully this helps
