- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi
I have a KDL-32W653A tv & have a question about Bravia sync.
The tv has 2 HDMI ports, I currently have a cable tv box connected to the 1st HDMI port & im thinking about adding a Sony blu ray player ( BDP-S4100 ) to the 2nd HDMI port.
I understand that the Bravia sync on the tv can control this blu ray player via the HDMI lead.
I possibly may in the future want to add on a Sony sound bar or home cinerma speaker system on, can this also be controlled by Bravia sync seeing as I will no longer have any HDMI ports on either Sony equipment spare?
Does Sony Bravia sync equipment only work over a HDMI lead?
Thanks
Lee
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
Bravia Sync only works over the HDMI connection. The term Bravia Sync is Sony's word for the more generic "HDMI CEC" Other brands call it differently.
Some of Sony's Soundbars have further HDMI inputs, which you can connect other HDMI devices to it. Soundbars such as the newest HT-XT1 or HT-CT370 and others.
The soundbar would need to be connected to HDMI 1 which supports the Audio Return Channel functions.
Hope that helps
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
Hope that helps
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
