A banner is on in the top left of the TV. This TV does not have a factory reset. How can I get rid of the banner.
Hi Clapham1941,
I'm glad it has worked. Could you mark my reply as a solution so other members having the same issue can find it easily?
Cheers,
Batee5
Hi Clapham1941,
Welcome to the community.
I'll see if I can find this out for you. Maybe someone else in the community can help in the meantime.
Thanks,
Pascale
Hi Clapham1941,
Welcome to our community!
Have you tried to press on the info button to remove it? It's the one on the left of the power button and has (+i) on it.
Let us know if this helps.
Cheers,
Batee5
