Hi There - hopefully a really easy question to answer (please....?)
I have a KD 65 AF9 and am looking to connect a UBP X800 4k UHD player to it - what HDMI socket is the best one to use?
I also have a satellite TV connection already on HDMI 2 - so want to optimise the way I use the system - I'm a novice so go gently!
It's OK - I think I found the answer - it seems that all the HDMI Connections support the 4k player - so no worries!
Hi Johnzoid!
So you're sorted?
Pascale
Yes Thank You!
