works for about an hour then turns off and on every few seconds. tried factory reset but did not fix the issue. Any suggestions?
Hi @gdpower
With a bit of luck you are still within your 5 year warranty (if bought from a major retailer). I would contact Sony for support a.s.a.p.
https://services.sony.co.uk/supportmvc/en/Contact/Email?cat=televisions-projectors-lcd-tvs&tab=Tips
Thanks for response.
out of warranty. Wondering if anyone else had similar problems and was there a solution other than bringing it to a repair centre
Hey there,
I would say if it stays long enough, make sure to check for a software update: https://bit.ly/3IAyyUx.
And if it's still the same, sadly you will need to contact an engineer about that one: https://bit.ly/3tE97K0.
Hope it helps!
