Hi all, Bought a Sony Bravia W82B, I cant find the internet Browser option? Im connected to wifi. Any ideas... tried Apps, All Apps, the centre round button on the control does not bring up a menu as it says in the manual. Any ideas what im doing wrong 😞
Unfortunately no, your model (2K - FullHD), has no chance to browsing web pages. Only if you send (Mirroring) the display from a compatible mobile devices.
Manolo
is it possible change 2k to 4k soft?
Is not the "soft", is the panel (hardware). Your TV is FullHD TV and nothing can change this... Only buy a different model.
Manolo
Same problem no web browser Sony 2017 model KD-V4QE2U6 . Go in to all apps all there are is 10 apps no brower
