We cannot record from the TV onto our external hard disc, despite all connections being verified and checked. The message 'Recording is only available with digital broadcasts' appears each time we go to record onto our Samsung Story external hard disc from the TV. All connections and installations are correct. Does this mean that our TV supplier has scrambled the programmes? Neither can we record from the satallite. Any help is much appreciated
As you said it in your post, "'Recording is only available with digital broadcasts' " so that's normal that you can't rec from satellite 😃
Recording is not compatible with video inputs either, it is only for Digital broadcast from the Antenna.
If your HDD is not recognized, make sure to format it in FAT32, and that the size is not over 1To.
