I found out if you leave just the soundbar on it will timeout and turn off.
Does anyone know long it takes to timeout?
As only discovered it did it at all when i left on overnight by mistake.
Thankyou.
Hi Wdp1234,
welcome to the Sony User Commnity Forum..:smileyhappy:
According to the user guide the soundbar enters standby mode after a preiod of about 15 minutes inactivity..
