nwwd help to connect my wii to my tv .i sky and ps3 in the two hdmi and dvd in the scart ,so im left with the coloured input but mine are red ,yellow and white and these dont match so cant get the wii to work anyone any idea
Hi there
According to the manual : HERE - you can connect the component cables (Yellow, White, Red) to the composite connection (Yellow to Green, White to White, Red to Red)
Failing that, you could purchase a composite to scart adaptor, and then a multiway scart switch. Or something in those lines.
Cheers.
Hi there
Cheers.
