I have a Humax HDR-1800T set top box and I wanted to connect to my Sony KDL-42W653A Bravia TV using a scart cable but on checking I cannot see scart on the input list although there is a scart socket can someone explain why have a scart socket if there is no scart input all there is is TV,HDMI 1,HDMI 2 and AV .What other method is there to connect mt set top box.
Thanks
Your TV is equipped with a Scart Input/output - see instructions:
https://helpguide.sony.net/gbmig/C5181001/v1/eng/c_t_europe_lw_rear.html
So you just can connect your receiver to this input and select AV from the input menu to watch content from it.
Any content intended above? If so, please try again.
